batterie kills it self in like and hour
RE: batterie kills it self in like and hour
Go out and test your battery and tell us what the voltage is with the car off. Then turn your motor on and let it run for about 5 minutes, retest the battery and tell us what that voltage is.
it has a brand new alternator,starter,but batterie some times it wont start after like 30 mins but when u psuh start it it will run fineas long as u dont kill it
before you go replacing anything, make sure your terminals are clean and the switch on the alternator is plugged in all the way. also, if its a rebuilt alternator or even a new one it could possibly be defective. test it out maybe you can get your money back.
ORIGINAL: slow 5 oh!
An altenator wont kill the battery while it sits. Either the battery wont hold a charge or there is a draw somewhere. if you have a test light, pull the neg cable off and let sit for about20 mins hook the light up to the battery post and terminal if the light is light youve got a draw somewhere. i would load test the battery first, i know most parts stores will do it for free if you bring the battery in the store.
Matt's 95 Stang
10-05-2015 07:16 AM
logan409
09-26-2015 07:43 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
