my tires
my tires
How wide of tires do you think i could fit up in the front of my car. Do you think it would be possible to fit 225s in the front. Do you think i could go any bigger. I was just wondering. Also what size wheel do you think i will need with 275/50/15, what size wheel do u think i will need. Also any offset or backspacing. Any help would be appreciated
RE: my tires
225s are stock so they better fit....
thats because you have a sn95, those would never come close to fitting on the fron of my car...[:@]
In my Sig I have 275/35/18's in the front and 285/30/18's in the rear
RE: my tires
ORIGINAL: ckyguy68
you can fit 235s in front, but they rub a bit. as for the rear i think 275 is the most. your need 7.5 inch rims for 275.
RE: my tires
245/40/r17 up front and no rubbing, are you buying all new wheels and tires? if so you need to decide on what size rims you want first, imo, 17" are best, then decide what width they are available in then choose tire size and 275 is a bigger size for the rear let alone for the front.
