Good heads for a budget build
RE: Good heads for a budget build
Does anybody know if you could really run 12s with #3?
http://www.hunterstyle.com/thumper/combos.php
ORIGINAL: NegadivOne
Used gt40ps are the way to go if you dont need to pass smog. a lot of shorty headers will work with them but you gotta wrap your plug wires.
289 are ok but id say no..get ya 302s redone with bigger valves..194/16 will flow and will notice a diff..gtp are ok but not worth it cuz you have a budget and cetain headers are needed...maybe gt40s or look on ebay alottimes you can finddeals..
My buddys neon had a cracked head gasket, and he was burning a very small amount of coolant. you couldnt tell from white smoke, but the coolant level was certainly going down.
ORIGINAL: Twisted
No answers, Peanut Jutter and Belly, but I do have a question. You say that your motor is burning coolant. What signs do you have that coolant is being burned? White smoke, or just a low coolant level? I ask because I was wondering if a motor could be burning coolant without producing white smoke. Thanks.
look in the "what our customers say" section. there are times in there.
ORIGINAL: BlackLX
Man, you should be able to find a good set of used heads for 500 without having to get the P heads. Look for used X heads or performer and trickflow. Have you checked the classified adds at www.corral.net ? I bought alot of good stuff there and got awesome deals. Bought a new edelbrock Rpm II on there for 350!! The E cam is a decent cam. Imrunning it in a 347. Im bout to switch it out for something bigger but it's a still a decent cam for a slightly modded motor.
ORIGINAL: ikeybmg
HOLY SHI@T.... HES ALIVE!!!!!!!!
