hang heads low, my 5.0's gunna blow
RE: hang heads low, my 5.0's gunna blow
I read that you aren't supposed to use that gunk motor cleaner for you oil if you have over 50K miles on it. It breaks up your oil but has chunks too large for your oil pick up filter to pass through causing higher oil pressure because of blockage.
Wow 300K miles? Impressive.
Good luck with your car.
kepp that auto a t5 swap is exp is your low on cash unless u find a used1 and then its used,,the$ u spend on a swap you can get a aod built...ill take a aod beefed up over a t5 anyday...blew 2 t5s havent on my aod in 4 yrs...i say get some lucus oil additive and go as far as ya can 1 qt added tocarin place of a qt of oil..wiill give you good oil pressure... for awhile.. godd luck
