Explorer Crank
RE: Explorer Crank
According to this, if its right, the firing orders are the same
http://autorepair.about.com/library/...bl-fo-9190.htm
http://autorepair.about.com/library/...bl-fo-5982.htm
RE: Explorer Crank
this will help you out hopefully...
http://boxwrench.net/specs_index.htm
the explorer has the standard 5.0L 302, the 5.0 HO has different heads/intake/cam, but the short blocks are the same on both the 302 and 302 ho's built after mid 80's, the 302's from '87 on they had a roller camshaft and fuel injection
