aod to c4
RE: aod to c4
Ok, hate to jump in on your thread here but I logged in to make a post about an AOD to C6 swap. My AOD is shot as well, and I can get a C6 pretty cheap. Is it the same basic idea? Is the C6 any good? Thoughts please.
RE: aod to c4
ORIGINAL: black89gt
a new bellhousing? wtf fords dont have a 2 piece transmission. lol it will bolt up to the block hbut you will have to modify the linkage and suck.
ORIGINAL: 85_HO_GT
maybe im stupid, or the whiskey is taking its toll, but cant he just take the bell housing off his aod and put it on his c 4?
RE: aod to c4
Well the c4 idea is not wat im looking for the more i learn about the swap, now im deciding on if i should get a built AOD like the streetfighter or go with a AODE. So it built AOD vs AODE with upgrade valvebody. Anyone?
RE: aod to c4
ORIGINAL: wlp302
This is 2006! Man walked on the moon ages ago. Why would you even consider a C4 or C6?
The 4R70W is dimensionally identical to the AOD.
Can you cut wires and solder?
A lower first and second gear should be enough to get you intersested. And still have OD for hwy use.
See photo:
This is just a plain old auto out of a wrecked 98 V6 Mustang. I gave 200 for it but since it has more than 130,000 miles on it, I will spend some money on it. It will be mated to a 351 Cleveland and placed into a 67 Mustang.
My other swap only had less than 30,000 miles on it so I skipped the rebuild.
The supporting computer cost $425.00
The 4R70W is better than the AODE. Different ratios and other improvements. Ad a shift kit and it's a great shifting tranny.
[IMG]local://upfiles/36086/ECC56284239646ACAAAB533AC1EE398F.jpg[/IMG]
