Battery in trunk??
Battery in trunk??
I'm not sure if anyone has done it, but if anyone has or knows anything about relocating the battery to the trunk/hatch please post I don't mind your opinion either so that will help too. I want to do it but I need the pro's & con's about it and is it worth it? Thanks!
Here's what I might get http://www.jegs.com/webapp/wcs/store...tegoryId=10367
RE: Battery in trunk??
Depends. Do you have any other weight reduction? Do you street race it? Ever go to the track? If you don't race it, then there's not much point to it other than to clean the engine bay up a little and provide a very nice spot to mount a MSD box. I plan to move mine in the not-so-distant future, but I run mine at the track.
i did it, when i can get my car to hook it deff makes a diiference.... if ur gunna run it at the track there are new rules! aluminum box(or blue nhra plastic) min of 5/16ths rod thro the trunk pan, with hold downs inside of the box for the batt. and an exteral kill switch in rear of car.................
I got the Summit deal. They want you to drop the tank everytime you need to take out the battery though. F-that. I went to Home Depot and bought a spring, and it holds everything done nicely, and it's a snap to take the battery out if I need to.
You do need to drop the tank though to install it.
Now you have a great place to mount you ignition.
