Racing a 350z today...gas?
Later on I'm going to race an automatic 350z
It should be a close race since they run 14s stock (automatic)
I just filled my gas tank up though, is that going to give me a bad disadvantage?
RE: Racing a 350z today...gas?
Ya its a disadvantage, each gallon weights 6.5 pounds, so if you had a 1/4 tank your car would weight about 80lbs less. You should be able to take a Z. I have beaten 3 stockers and ran neck and neck with one that was modded(Exhaust, Intake, Tune).
ORIGINAL: 83gtragtop
a Z has this for power:
VQ35DE—3.5-liter DOHC 24-valve V6 engine (M/T models)
300 hp @ 6,400 rpm
260 lb-ft @ 4,800 rpm
Unless you have 300hp, I think he might have you covered. You'll torque him out of the hole, but he'll run you down.
What's you motor combo?
300 hp @ 6,400 rpm
How much does a stock Z weigh? If it weighs considerably more than a mustang than don't worry about the gas, but definitely don't use gas weight as an excuse if you get beat. But I'm sure that you won't since you drive a mustang and not a civic.
