MAF ????
RE: MAF ????
not alot... before we get too far into this. check the part number on YOUR maf, and the part number on the one that you might be buying
mine is
F2VF-12B79-A1A
AFH70-04
4C22
thats exactly how its seen on the MAF itself... you may find out that you already have a 70mm, in which case, you dont need to upgrade
mine is
F2VF-12B79-A1A
AFH70-04
4C22
RE: MAF ????
adder ill check the part number tomorrow, the one I was bidding on went for $26.00 should I have just baught it? i went to the brooks and dunn long haul tour concert and missed out on it!
RE: MAF ????
thanks will.... i thought so but i wanted strongstang to check his out. i had a feeling it was the same but i wanted to check the numbers
and the maf's should be exactly the same if it IS a 70mm, the 19# and 24# tuning is in the ECU, not the MAF
