Running hott and acting sluggest!!!!!! - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 09-11-2006, 05:28 PM
5.0GTConveritbleGuy
Default Running hott and acting sluggest!!!!!!
Ok i drive a 89 GT converitble and i replaced the T stat with a 195* and put new collant in her, and she is still running in the hight normal range, to the point where i have to drive with the heat on full blast and not doing anytype of driving fast or any smashin, or it will go up. 2 days ago i just let it go up and in started making the loud *** rattiling sound and the temp was close to the red, above the N on the gage, so i pulled over and popped the hood and turned the heat on and after about 2-4 minutes it stopped. I dont understand whats going on and also when it gets hott its gets real sluggest, to the point where that day i put it to the floor and it barley went anywhere. It took a whlie like a good 10sec for it to get going fast. So can anyboys please tell me what could be possible be going on!!!!!!
5.0GTConveritbleGuy is offline
Old 09-11-2006, 06:51 PM
93must
Default RE: Running hott and acting sluggest!!!!!!
Could be a blown heaed gasket! Check your oil and see if there is any water or anti freeze in it. It will be a milky color if there is any! Your car running hot like that will really kill your HP.
93must is offline
Old 09-11-2006, 06:54 PM
leadfootdriver
When your car car gets to like 190* it goes into a low performance mode; even the A/C won't work. A 180 T-stat is a better choice if your car runs hot.
leadfootdriver is offline
Old 09-11-2006, 07:00 PM
MEM 302 5.0L
i put an electric fan in mine once...and (it wasnt very good) ...it lugged my alternator and battery down and wasnt cooling right...and it made my car sluggish ...and the a/c quit working....so i just put the stock clutch fan bak in.........i doubt that helps ne..but just sayin...
MEM 302 5.0L is offline
Old 09-11-2006, 09:09 PM
fordboyyfm
did you drain the coolant from the radiator? how did it look, did it drain out real slow or normal. radiator could be clogged. i would also make sure the fan is working properly. make sure it doesnt spin really easy (if its the stock) or if you have electric make sure its working good.
fordboyyfm is offline
Old 09-11-2006, 09:19 PM
PONY GUY
you might have a air bubble in the system . Jack the front up and take a rad cap off and let it run for a while till th coolant over flows and the system burps
PONY GUY is offline
Old 09-11-2006, 09:36 PM
Sk8trfred
ORIGINAL: MEM 302 5.0L
you wouldn't happen to be selling that fan are you? if it's still around that is
Sk8trfred is offline
Old 09-11-2006, 09:43 PM
MEM 302 5.0L
it quit working....lol....the fan motor locked up
Old 09-12-2006, 05:40 PM
5.0GTConveritbleGuy
Alright thanks everybody, ima try what y'all have suggested to me and ill let y'll know what happeneds.
Old 09-12-2006, 05:55 PM
vristang
ORIGINAL: 5.0GTConveritbleGuy
Start out by pulling the codes.
vristang is offline
carid
07-08-2016 10:55 AM
heslekrants
09-23-2015 05:02 PM
uedlose
09-10-2015 04:30 PM
96stang3.8
09-10-2015 07:42 AM
zanemoseley
09-06-2015 01:58 PM
Quick Reply: Running hott and acting sluggest!!!!!!
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
