Got the new ride
Got the new ride
Just picked it up from the dealer tonight.....and let me tell yah what i love it it is way faster thne my other one .....well here is the mod list. and what kinf of HP is this thing kickin out and what do you think my 1/4 mile time will be????
331 C.I stroker
forged steel crank
forged pistons
H beam rods
trick flow stud girdle
high volume oil pump
comp cams 274 HR cam 555/565 lift
trick flow aluminum track heat heads milled
10.5:5 compression
ford motorsport 1.6 roller rockers
24lb injectors
aero adjustable fuel pressure regulator
trick flow track heat intake
65mm throttle body
bbk cold air induction
mac full lenght headers
pro chamber h-pipe
mac cat back exaust
3.73 gears
sub fram conectors
flaming river maunel rack
T-5 trans
spec stag three clutch
hurst shifter
griffin aluminum radiator eletric fan
5 lug conversion
rear disc brakes
battery reloction
331 C.I stroker
forged steel crank
forged pistons
H beam rods
10.5:5 compression
24lb injectors
65mm throttle body
pro chamber h-pipe
mac cat back exaust
3.73 gears
sub fram conectors
T-5 trans
hurst shifter
5 lug conversion
rear disc brakes
battery reloction
RE: Got the new ride
I paid 8900 out the door and traded my car in.....but i still owe 3000 grand on my other stang so they are payin that off....so all and all their giving me 5000 for my car....which as 160k miles on it some cobra "R"s and basiclly stock...so yeah i got a nice deal cuz my uncle is the dealer
ORIGINAL: MustangKid5.0
it's a 92 Gt with a stormin norman hood. stalker front end. saleen wing. cobra rear. fresh whit paint sliver cobra R's with 275/50's all around
(your front tires are probably 245/45/17)
