Cecil Drags Friday?
Old 09-12-2006, 02:26 AM
SSKiller
SSKiller's Avatar
Default RE: Cecil Drags Friday?
Yeah I see the breather......then crankcase pressure should be ruled out.
With the 255 you won't need to change anything........I have a stock maf and stock injectors....and I have one.
A 255 will never fall behind a high fuel demand at the top end.
Check the motor mounts (esp the driver side one), tranny mount, and jack up the rear end and wiggle the drive shaft. If there is play in it....then replace the U-joints. All of these above were the problem in my car.
SSKiller is offline
Old 09-12-2006, 02:34 AM
dimebag
dimebag's Avatar
if the weather holds out ill be there no question. i wanna see what this beast of a fully stock 5.0 can do, lol. but no, i need some base numbers to compare to later(n just like goin to the track)... so ill be there. its about a 30-35 min drive for me too... where u comin from?
dimebag is offline
Old 09-12-2006, 03:01 AM
dimebag
dimebag's Avatar
Default .
that... or go wed...
dimebag is offline
Old 09-12-2006, 09:14 AM
1bad87
1bad87's Avatar
Default RE: .
i live right here in rising sun where the track is, im about 5 mins from there
1bad87 is offline
Old 09-12-2006, 09:15 AM
1bad87
1bad87's Avatar
thanks man, im gonna try and check that stuff out here asap. if i dont get a chance im gonna wait till next week to race again. i definitely dont wanna go tear somethin up bc i was too lazy to check stuff out.
ORIGINAL: SSKiller
1bad87 is offline
Old 09-13-2006, 12:05 AM
1bad87
1bad87's Avatar
sorry fellas not gonna make it now. i forgot i have hunters safety course to take this fri and sat night and next fri and sat nights
1bad87 is offline
Old 09-13-2006, 12:16 AM
ZachW04Stang
ZachW04Stang's Avatar
Good luck, I won't be able to make it but cecil is a great track to run at on fridays. Just make sure you get there early because they get packed fast. Normally I only get 2 or 3 runs in on a friday night. Wedsnesday you can normally get 5 or 6 runs in if you get there early. Cecil is also a track where you hook hard, you can expect times at cecil to be .3 to .5 lower then capitol raceway.
ZachW04Stang is offline
Old 09-13-2006, 01:05 AM
dimebag
dimebag's Avatar
^thats all good to hear. im deffinatly gonna go, i think im goin tomorrow... and if i can ill go fri too. unfortuanitly i no i wont get the best time i can... cant slam 2nd... syncro is startin to go... but i still want to go just for a general idea of what i got in it, and ive never ran anything before... so it should be fun.
dimebag is offline
Old 09-13-2006, 01:22 AM
ZachW04Stang
ORIGINAL: dimebag
I might drive up there tomorrow just to watch the races.
Old 09-13-2006, 01:39 AM
dimebag
dimebag's Avatar
well hey if ur there...look for the white hatchback runnin high *** 15s prolly... lol u gonna ride up in ur stang?
dimebag is offline
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
09-15-2015 07:34 PM
Quick Reply: Cecil Drags Friday?
