offset rack bushings install question..
RE: offset rack bushings install question..
Remove the nuts from the front of the rack then pull the bolts back until the rack is off them. Remove the rubber bushings from the rack and install the new ones in there place. You probably will have to loosen the steering shaft because of the offset will put the rack in a different spot. Install the rack withe the 2 nuts and bolts and tighten the steering shaft. Last get it aligned
09-01-2015 08:16 PM
