Flywheel
Flywheel
How difficult is it to strip the teeth off a flywheel.. i just got a new high torque mini-starter and it isnt catching on anything anymore... it always made a little bit of a grinding noise after the install and about a month later it doesnt grab anymore... it isnt a stock flywheel, it is a billet steel flywheel... it happened to my previous starter and i thought it might be the starter(just a factory one), so i pulled it out and there were little nicks on the starter teeth, but nothing major, and it was completely functional on a bench test...
RE: Flywheel
ORIGINAL: redmustang83596
RE: Flywheel
Most likely your bendix spring broke happens very ofter especially if its not meshing with the flywheel perfectly, it will kill starters quickly...just happened to me twice in a month granted the first one was old and the second one was used... and on a bench test it will still spin it just doesnt push out because the bendix is broke.
RE: Flywheel
ORIGINAL: saylor
RE: Flywheel
The bendix wasnt broken, the drive gear did push out. I was at a tech school when i tested it and my instructor said he didnt know what was wrong with it. This problem is really making me angry, since I have long tube headers, its a PAIN IN THE A$$ to get the f-ing starter out. Takes me a couple hours just to get it out, and putting a new one in takes a lot longer. I have no idea whats wrong with it, but it just spins and doesnt even hit anything. It always made a little bit of a grinding noise when starting after the install, then it got worse and then it wont even hit the flywheel all-together. It just spins...
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
