Notching Pistons for 185's
#35
RE: Notching Pistons for 185's
No problem at all. I want you to steal it lol because I am going to be running the same setup as you are and since your one step ahead of me I can learn from your mistakes! LoL hahah JP!
But head studs are not a bad idea at all and ALSO I believe hardened pushrods are a neccessity. Not sure on the rockers though... Im definetly rocker retarted [8D]
#36
Trust me. I'll make plenty, my friend. I'm good at that. I'm buttoning up the Black Magic Xtreme electric fan install tonight and a word to the wise, don't bother with the a.c. or manual hookup. It doesn't come with the manual switch and the a.c. splicing would make the wires have to go across the radiator, unless I got it wrong. Once you set the temp control, the fan would come on anyway, so I'm not sure I see the need for the a.c. tie in.
Any idea on what length pushrod is needed or would the place you get the heads from know that?
#37
Read the thread right now called "lifters, rockers, pushrods" or something like that. Joel5.0 posted a good calculator on there to determine correct length for your pushrod. I didnt even look at it yet but I will in a few.
uberstang1
09-20-2015 06:42 PM
