horrible vibrations
horrible vibrations
The ladys love it but it drives me insane, i just had the trans and clutch replaces and all new wheels and tires perfectly ballanced, it had the vibration before i did all this, the trans blew up and i thought that was the problem so i got a new one and had a full alignment done, and it still makes a horrible vibration, it doesnt seem to be threw the sterring tho, more seat of the pants, and it doesnt start till around 45-50 mph and it just gets worse at a steady rate when i accelerate,and i mean it gets bad, at like a 100+ i think im going to die, or the wheels are gunna fall off, i mean its just scary, im thinking, maybe the drive shaft is out of balance, or the rear has a bent axle or something, i have a set of 373 im planing on putting in but i was trying to find out what else i should up grade at the same time, like 31 spline axles and a 31 spline lsd and an aluminum drive shaft, i was wondering what you would suggest i replace these parts with, its a 1994 GT 8.8 rear, 5speed, i have a stage 2 clutch, i have the gears already so what else should i get,
Thanks
Ted
Thanks
Ted
RE: horrible vibrations
ORIGINAL: stang94gt
Thanks
Ted
Thanks
Ted
-P.
ORIGINAL: P Zero
If it shakes the seat of your pants its coming from the rear of the vehicle. Im thinkin that your driveshaft is "out of phase". Meaning they didnt re-install it in the same position as they took it off in. Youre supposed to mark the yoke and the pinion flange with some paint or a mark you can recognize and re-install it the same exact way. IF its not itll cause bad vibes.
-P.
ORIGINAL: stang94gt
Thanks
Ted
Thanks
Ted
-P.
