X pipe or H pipe which one is good???
RE: X pipe or H pipe which one is good???
a H-Pipe and an X-Pipe do the same basic thing, they allow the exhaust preasures to equalize to help with exhaust scavaging, which helps with velocity and better flow.in theory, the X is a better desin since it has less resistance than the H, in real world situations, both are about the same for street cars. In high horsepower situations, an X is better, almost everyone in NA$CRAP uses a X. They do have a different sound than each other.
In general an X-pipe will give you a bit more high end power then an H-pipe and a H-pipe will give you a bit more low end power. When I say a bit I mean it's almost insignificant. If you bought an aftermarket version of either you will see a good improvement over your stock h-pipe.
An H-pipe produces a deeper muscle car tone, while an X-pipe produces a loader racier tone.
Hope that helps.
Hope that helps.
A lot of it depends on personal preferance. There's a difference in sound, and the X is supposed to flow a little better than the H, but I doubt you could tell the difference between the two in the seat of the pants.
I have an X, and I'm satisfied with it, if that helps any.
ORIGINAL: xnext
but my pipes isent after market is "home made" WITH 2 1/2 tubing do i put the h pipe 2 1/2 to or samaller??
ORIGINAL: ncksnapper
or you could just the search button since its been talked about 1000 times
It appears the only acceptable way for a beginner not to offend the locals is to post their naked gf/wives first, then ask questions. This tidbit of information needs to be added to the registration form asap.
