need help with 302 engine build.
Old 09-13-2006, 01:27 AM
anthros
anthros's Avatar
Default need help with 302 engine build.
My engine is a 1985 ford 302. Iam torn between the afr165 and the afr185 heads, does anyone have any opinions on either? what cam, rockers, and rods would you guys recomend with afr heads for mid-high end power?
anthros is offline
Old 09-14-2006, 06:40 PM
deadcarnahans
deadcarnahans's Avatar
Default RE: need help with 302 engine build.
I would use the 165s, a custom grind Comp cam about .512 lift / 218-224 degrees duration @ .050 and Comp roller tip rockers. This would pull strong through the mid range and not break any parts.
deadcarnahans is offline
Old 09-14-2006, 06:41 PM
88BlueGT
88BlueGT's Avatar
If you plan on keeping it NA than you can really go with either one. The 165's would be a little bit more in your area though. But if you plan on strapping a SC or Turbo on than you should look into the 185's.
88BlueGT is offline
Old 09-14-2006, 06:44 PM
r.barn
r.barn's Avatar
AFR 165's with TrickFlow stage 1 cam
remember to upgrade pushrods and lifters at same time or expect problems.
r.barn is offline
Galactic
04-29-2019 02:56 PM
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: need help with 302 engine build.
