Explorer intake maniforld and TB
Old 09-13-2006, 02:11 PM
89regattaLX
89regattaLX's Avatar
Default Explorer intake maniforld and TB
I have the upper and lower intake manifold from a '99 explorer that I'm gonna put on my car soon and I've heard that they are gt40 intakes but the numbers on it are the same as the cobra intake so which is it? I also have the throttle body and was wondering if any one knows the size of it.
89regattaLX is offline
Old 09-13-2006, 02:13 PM
5speed GT
5speed GT's Avatar
Default RE: Explorer intake maniforld and TB
the cobra intake is a gt40 intake.... on the inside
5speed GT is offline
Old 09-13-2006, 02:14 PM
Twister
Twister's Avatar
it is neither, and the EGR system is not compatible, you will need to modify the intake. The lower is basically the same as a Cobra/GT40, but the upper is unique
Twister is offline
5speed GT
5speed GT's Avatar
I stand corrected, i guess the lowers are the same
Old 09-13-2006, 02:16 PM
4fit?
4fit?'s Avatar
They are basically the same as the Cobra. As for the tb size, just measure it. I'm not sure what it is off the top of my head. I could be mistaken, but I don't believe the 99 intake would have EGR provisions. Seems like they stopped having the provisions mid way through 97. Just something to keep in mind.
4fit? is offline
Old 09-13-2006, 02:17 PM
Twister
Twister's Avatar
the explorer has the runners of a Cobra and the plenum of the GT40....but does not work as well as either of it's predisesors....
Twister is offline
Old 09-13-2006, 02:18 PM
89regattaLX
so should I ditch the upper for something else then?
Old 09-13-2006, 02:19 PM
5speed GT
5speed GT's Avatar
I wouldnt, the difference you would probibly never notice, you have that now, I say slap it on there
It will def flow better than the stocker
Old 09-13-2006, 02:21 PM
4fit?
4fit?'s Avatar
It will take quite a bit of modifications to get it to work properly with your car. I'd sell it and try to find a pre 97 Explorer manifold, CObra, GT40, etc, etc, etc.
4fit? is offline
Old 09-13-2006, 02:31 PM
5speed GT
5speed GT's Avatar
sorry to jack the thread, but are the 96's different than the 99's(other than emissions stuff)
Quick Reply: Explorer intake maniforld and TB
