DOING THE RESISTOR THING DOES WORK update
RE: DOING THE RESISTOR THING DOES WORK
well the canistor wire looks cooked so who knows...3 wires right?...this one does...
bright side is there is no cel...when i push in clutch or shift idle doesn't drop or die...
idle does hang a little,but you said that's common right?...i have my idle set right at 850rpm.
560 ohms and a 150 in series makes it 710 ohms, and 560 and a 150 in parellel makes it 355 ohms.
ORIGINAL: grabbem88
well this is the problem....i did the egr thing,but had no 390 ohms...so i used a 560 and a 150 in series so that makes it a 410 ohm..i did use the 3.9's.....i have no cel what's so ever, but the 85,and 34 still comes up the rest are gone though.....here's the thing since i'm killing power by kill switch...the computer still has "stored" energy right?...how do i clear that stored memory?
btw my idle is perfect with no fluctuation whatsoever...
the one i missed....you said 4 so i bought 4...now if this is right about being on the lower intake pass side..???
i have one 150/3.9k's/10/and a 470ohm all 1/2 watts...no more 75's
