PLEASE READ HAVE A QUESTION.
well here's the deal...i got every code cleared,but one and that's 34,and i think i know why.
making up the resistor triangle basicaly just keeps the CEL off...which is cool for me... all the 8* codes are gone,and the rest that popped up also.....does it run better?...throttle response seems more crisp...also my t.p.s was 1.09 so i put it at .998..... now i do have one issue..idle surge is still present...will my mass air meter create such problems...what are the steps in checking the meter?...volt checks/load?...is it because i have 24's/meter also. |
RE: PLEASE READ HAVE A QUESTION.
man WTF???? nobody has any answers?....
ORIGINAL: grabbem88 man WTF???? nobody has any answers?.... |
i work 16 hrs a day 6 days a week....i'm supposed to be in bed right now....i cleaned the meter two or three times already.....
i'm just confused i help all i can,and most of the time get called a dumb ass...then later on i see a post how"they" fixed it all by them selves with absolutely no recognition of whom gave the "correct" info,and pointed them in the right direction.... when i have a suggestion/question/problem i get zilch... BTW don't make comments like that when you are on here just as i am...we are on here for a reason. |
ORIGINAL: grabbem88 i work 16 hrs a day 6 days a week....i'm supposed to be in bed right now....i cleaned the meter two or three times already..... i'm just confused i help all i can,and most of the time get called a dumb ass...then later on i see a post how"they" fixed it all by them selves with absolutely no recognition of whom gave the "correct" info,and pointed them in the right direction.... when i have a suggestion/question/problem i get zilch... BTW don't make comments like that when you are on here just as i am...we are on here for a reason. |
Check your other thread for code 34, if you still have a little surge when its idling at op temp.....unscrew the throttle blade stop screw (same as lowering base idle) slightly....turn engine off, wait 5 seconds, restart engine and check idle again.....repeat if necessary, unscrewing the stop screw a little at a time until the surge is gone.....OH!...don't worry about the TPS voltage as long as it stays between .8vdc and 1.0vdc....the EEC-IV sets the angle to 0° everytime you turn the engine off, and turn it back on automatically, as long as it stays within .5vdc and 1.1vdc (.8-1.0 is a range to "provide" for VREF variance and ground noise)....
man if you think that was "jumping" all over you....i will make sure to stay away from you....i call it like i see it....BTW this was actually a piggyback of a prior post of two days ago..
ORIGINAL: Twister ORIGINAL: grabbem88 i work 16 hrs a day 6 days a week....i'm supposed to be in bed right now....i cleaned the meter two or three times already..... i'm just confused i help all i can,and most of the time get called a dumb ass...then later on i see a post how"they" fixed it all by them selves with absolutely no recognition of whom gave the "correct" info,and pointed them in the right direction.... when i have a suggestion/question/problem i get zilch... BTW don't make comments like that when you are on here just as i am...we are on here for a reason. |
both of you guys... LET IT GO![:@] jeeze, i feel like im surrounded by 13 year olds.
i'm done CK i was trying to do a good thing so this could all be used to help new commers....as far as i'm concerned it's sqaushed..end of the little fight....just remember who you are when i offer help.
but i must say, twister did overrecact a bit when he had his wife read the post, then stated her opinion on the situation. like we really care:eek:
ORIGINAL: grabbem88 i'm done CK i was trying to do a good thing so this could all be used to help new commers....as far as i'm concerned it's sqaushed..end of the little fight....just remember who you are when i offer help. |
