help with my shiity numbers
well i got my trocl flow top end, car is finally running, had ot have a shop get the timing on and **** and they ran a fast dyno came out with poor HP numbers but about 289 torue at the wheels so i guess thats good? i may have ****ed up somewhere adn if i did someone tell me
trick flow HCI setup 24 lb injecors, headers, pullys, 255 pump, 70mm TB 75 MAF, clutch, i may be missing something here but my HP was like 250 at the wheels
o eyah nkg plugs msd wires and msd dist cap
RE: help with my shiity numbers
All I can say is this... whoever you took your car to tune I would stay away from. Any decent tuner would of realized that something was right there and that those numbers were very low... especially the torque.
BTW, what is your timing set at right now?
Put your fuel pressure at a stock 39 psi. That's a whole lot of fuel pump for any natural aspirated ride. Your computer will take care of the mix just fine. If you have the stock FP regulator, I bet the 255 is overpowering it.
09-23-2015 01:28 PM
