How do you Roll the Fender?
Old 09-16-2006, 02:14 PM
5.0 MPG
5.0 MPG's Avatar
Default RE: How do you Roll the Fender?
ORIGINAL: sennf1
go to rollyourfender.com. you can rent for 50 dollars with 250.00 deposit and you pay shipping both ways. I rented it last year, it takes a little while to get the fender rolled but it works really well. I have a new paint job and it did no dammage to my quarters. I only rolled the rear quarters. I did not roll the front fenders.
good one!
5.0 MPG is offline
Old 09-16-2006, 10:01 PM
mpswirl
mpswirl's Avatar
When you roll the fenders its a good idea to heat the paint up with a heat gun because it will crack the paint on the outside when it bends.
mpswirl is offline
Old 09-16-2006, 10:22 PM
Hung Like a Stang
Hung Like a Stang's Avatar
whats the baseball bat method?
Hung Like a Stang is offline
Old 09-16-2006, 11:12 PM
mpswirl
mpswirl's Avatar
The bat was an old trick, you put the bat between the tire and the inner fender. Then you roll the car very carefully, while the car rolls the bat gets sandwhiched between the tire and fender which then bends the fender. This is a very old way to do it and i found that some cars are so lowered the bat wont fit between them. Get the tool to do the job correctly and make sure you heat the paint or it will crack. I used a heat gun but be careful with that to.
mpswirl is offline
Old 09-17-2006, 12:19 AM
ZachW04Stang
ZachW04Stang's Avatar
Shocks won't cause a car to sag. If your shocks aren't bad I wouldn't replace them.
ZachW04Stang is offline
Old 09-17-2006, 01:43 AM
94Cobrakid16
94Cobrakid16's Avatar
but they could be softer then they should right? i already got new ones ive just yet to put them in.
ORIGINAL: ZachW04Stang
94Cobrakid16 is offline
Old 09-17-2006, 04:15 AM
85_HO_GT
85_HO_GT's Avatar
shocks dont affect ride height at all. its job is to keep your tire on the ground, and absorb some the road vibration. changing your shocks will not solve your problem. your springs on the other hand are a different story.
85_HO_GT is offline
flash_xx
10-16-2015 07:23 AM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
ThatJuanStang
09-25-2015 08:01 AM
zachary1988
09-18-2015 11:17 PM
Quick Reply: How do you Roll the Fender?
