No idle, none at all
Ok, i finally finished putting my motor back together. i did a h/c/i swap. New injectors, new MAF, new TB and TB spacer. I removed all the smog and a/c crap also. I started it up, and it starts fast, no hesitation, but there is no idle at all. it just dies when you stop giving it gas. i just replaced the iac gasket because i thought that was it, but no better. also, a new tp sensor came with the tb. Any ideas?? I need help bad!
RE: No idle, none at all
ok, yea im sure it has some vac. leaks somewhere, i had to plug alot of holes from removing smog/ac. Ill clean the IAC valve, but it idled fine when i took it apart, so could the IAC valve still be the problem?
yes, mine idled fine before I did an H/C/I swap.
then like crap after, replaced the IAC valve, messed with the idle set screw, messed with TPS voltage, it helped.
These head cam intake swaps dont just bolt on and wha la it runs fine.
you gotta tinker with it a little
ok, thanks. How do i set the TPS voltage? And the idle set screw is on top of the TB right? How should i adjust that? sorry if the questions seem stupid, still learning!
OK, i adjusted the tps voltage to .89v, i put vacuum caps on all unused holes, and cleaned the IAC with brakeclean and still no idle. I have been messing with the timing and no progress. Its really strange. When i try to start it there is nothing. It doesnt stumble or even try, and as soon as i give it a little throttle if fires right up. Im really stumped and wanted to get this thing on the road asap!
