exhaust leak???
exhaust leak???
hi im thinkin my headers might be leaking cause lately inside the egine compartment its been really loud, how can i tell for sure if i do, is there a way??? im gonna go tighten the header bolts today, if that doesnt seem to work what should i do, thanks a lot!!!
RE: exhaust leak???
i had the same problem with my 92 gt, what i did was first i tightened the header bolts, that didnt work so then i replaced the exhaust manifold gaskets, that didnt work, so finally i got rid of the h pipe all together and got a catless xpipe and guess what !!that didnt work either so i have no idea maybe that hiss is just a natural mustang sound
RE: exhaust leak???
With the hood open, motor running at idle, and a friend handly, have him take a couple of rags and block both exhaust pipes briefly with the rags while you listen under the hood for sounds of an exhaust leak. If you got one, this will make it very apparent where it is.
I would do this first before I tighten up any bolts on the headers unless you know they are loose.
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
