running out of gear (top speed)
#21
RE: running out of gear (top speed)
+1 just switch back to like 3.50 gears, thats gonna be easiet thing to get what you want.
ORIGINAL: whiteout 5.0
stock aod gears
minor bolt ons
all suspension
157mph
its the gears
i run 225/55/15's
stock aod gears
minor bolt ons
all suspension
157mph
its the gears
i run 225/55/15's
#26
i would never do it on the street
done it on the highway twice
anything above 110mph in an AOD-anything in 3rd gear is really pushing it.
i only got to 125mph in 3rd because it wouldnt shift into 4th and just climbing rpm's almost shat my pants
#28
ORIGINAL: AdderMk2
I believe your pleas are falling on def ears. If I was in his position, i'd get 28" tires(drag preferably) however, not very many people have the same level of common sense that we do.
ORIGINAL: 4fit?
Like stated earlier, 28" tire is the cheaper, possibly better, way to go. Or you could mess with the rear gearing. But, I strongly suggest going with a 28" tire and get the correct speedo/drive gear for the combo.
#29
ORIGINAL: samseed101
Has nothing to do with falling on deaf ears. has to do with state inspection laws. If i run anything with a larger (or smaller) circumference it won't pass inspection. But like I said earlier, I just may have to do it anyway and deal with it later.
ORIGINAL: AdderMk2
ORIGINAL: 4fit?
i know its on the books, but do they actually enforce that? get an extra pair of stock wheels from a junkyard for every other year when you need to pass inspection maybe?
#30
ORIGINAL: Blue Oval
