Another not starting problem......
After an 8 month build I think I am on the home stretch. I had the car running and in good order, when an old problem cam back to haunt me. I had to remove the uppe and lower intake and the distributor to fix it. Long story short, the car wont start know that is back together. It just makes a clicking sound, doesn't start over. the sounds appears to be coming from the engine somewhere. A prob with the distributor maybe. I check the battery and it is fine. Any ideas?
Thanks in advance
Thanks in advance
RE: Another not starting problem......
if you get selonoid click and no start, check the starter first then http://bellsouthpwp.net/l/r/lrichker/index.htm this is the man full run dwn of all no start issues to a 5.0l car
dalefrancis88
09-11-2015 07:15 AM
