Custom Chip Question
I just found/spoke with the guy who built my car--2 owners ago
He told me my car has a custom chip to the build you see in my signature.
If I change to a 76mm Mass Air and 30lb injectors(currently stock Mass Air and 24lbs) after I repair my heads will the Custom Chip be way off?
RE: Custom Chip Question
The FMU's are a bit of a hack way of getting more fuel.
It would be better to have the computer tuned.
Your chip will most likely be off, if the custom tune was done correctly.
You need to know where the chip came from and how they tune their MAF/Injector setups.
Most tuners will modify the MAF and Injector settings in the EEC-IV. If your settings have been modified, then you will have to get the car re-tuned.
Let us know how it works out.
jason
jason
I would than go for a used set of 36lb injectors.... 42's might be a little big but the 24's are definetly not enough. Also, screw the FMU. They are garbage... get everything setup and go get a tune.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
