Will the Trick flow package work with...
RE: Will the Trick flow package work with...
To be totally honest I would go with the TF kit. If I were you I would go with a set of AFR 185's, track heat manifold and a custom grind... that would make a decent amount of power over a trickflow kit.
It WILL work with your car and it WILL give you alot of power over stock BUT for your application I would go with something that flowed a little better. And also, a 306 is not a stroker. Not trying to be a d*ck or anyting just letting you know
NorthAmericanTuning
11-09-2016 11:44 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
09-01-2015 08:16 PM
