knock sensor question
I HAVE A NEW ENGINE,306 WITH AOD IN 1987 MUSTANG..MY PROBLEM IS THAT THE ENGINE NEVER PINGS AND HAS POOR PERFORMANCE, EXPECIALLY IN THIRD GEAR AND OVERDRIVE..I HAVE CHECKED AND RECHECKED, AND RESET EVERTHING MANY TIMES AND STILL POOR UPPER RPM POWER.. I NOTICED FINALLY THAT THE KNOCK SENSOR SEEMS NOT TO HAVE BEEN CHANGED TO NEW ENGINE..DOES ANYONE KNOW IF THE CPU RETARDS TIMING IF SENSOR DISCONNECTED??? I FIND NO OTHER SENSOR PROBLEM AND MOST COMPONENTS ARE NEW..ANY INPUT WOULD BE HELPFUL..THANKS: AL
RE: knock sensor question
I was under the impression no knock sensor is used, since I wanted to know about timing gears once, but it said "Not for use on vehicles with knock sensors" so I asked on a board and they confirmed 5.0 do not use knock.
Could you show me where?
or look at the ECM pinout tables now....a '87 4 cyl. engine Mustang....sure!...
or check the table of the EEC-IV systems it is used on at http://fordfuelinjection.com/index.php?p=34
I DONT KNOW WHERE IT IS LOCATED, I HAVE YET TO LOCATE..I HAVE CHECKED WITH SEVERAL AUTO SUPPLY STORES, EACH INDICATING THAT A KNOCK SENSOR IS USED ON 1987 EFI 5.0 H.O. WITH AOD...I HAVE NOT HAD TIME TO LOCATE YET..I WILL LET YOUKNOW IF AND WHEN I LOCATE..I HAVE ALSO BEEN ON THE INTERNET AND HAVE FOUND SEVERAL SITES SELLING THE SENSOR.. JUST GOOGLE KNOCK SENSORS AND SEVERAL SITES WILL APPEAR....AL
ORIGINAL: jockoal
I checked with ford and found indeed my vehicle uses a knock sensor..it is located on the right rear of the intake manifold....1987 mustang 5.0 h.o. with aod trans..when i had the engine changed i also changed intakes, i asked to have my original manifolds returned..upon inspection today i found the sensor still in my original manifold in the right rear location..i did not know until today that this was the knock sensor, since most knock sensors are located on the side of the engine block.....know i only have to find the computer wire and attach hopefully the sensor is still good, if not buy new no big deal..if anyone knows what the wire color code from sensor to cpu, would appreciate data, as i think they may have snipped it when changing components...its good news anyway as know i know why engine power has been so poor at higher speeds..cant wait to hear an engine ping..al
