drowning my motor
drowning my motor
I have a 347 stroker motor with 11.5:1 compression, 36# injectors and pushing 42psi of fuel at idle. I am running trick flow twisted wedge heads and an e cam with 1.7 roller rockers. Could I be running to rich and robbing power?
RE: drowning my motor
or if you have an adjustable fpr (i would hope so...) you can just turn the pressure down till it pings and then turn the pressure back up a few psi from where it started to ping. crude, not exactly the safest way to do it, but it will work.
logan409
09-26-2015 07:43 PM
