RollCages!
RollCages!
I been reading around. Whats teh deal on Bolt IN Roll cages?/ Are they legal? Are they stronger or weaker?? Will they rip out of the floor pan and wheel wells> or is i better to get. If i am planning to only go 11.5 ET in da 1/4 Is it NHRA LEGAL??? Please help, I would hink about bolt in!! But i dont wantto sacrifice safety by the way.
[IMG]local://upfiles/49087/B5122D8E3FE84696BC8D28C21CDB149D.jpg[/IMG]
RE: RollCages!
They are legal if installed correctly. If I remember right you need to use a 6' x 6' by 1/4' steel plate on the bottom side of the car where the bar bolts in. You also need 5/8's grade 8 bolts. The info is in the NHRA rule book, I would double check me because I am just going off what I can remember, so my numbers might be off. You can always get a bolt in cage welded in later on if you want.
RE: RollCages!
You don't need anything for a 11.5 unless you're a 'vert. I wouldn't do a bolt-in. I think they are for looks. If someone has one and tells me they did it for safety, I tend to think they don't understand the concept.
RE: RollCages!
ORIGINAL: FullAuto
RE: RollCages!
ORIGINAL: randy78045
If youre not a vert, what's the limit???
ORIGINAL: FullAuto
RE: RollCages!
ORIGINAL: klapdout
bolt in cages will never, and can never be as strong as a weld in cage, dont play games with your saftey use a welded cage
