how to route PCV?
how to route PCV?
Just like the title says, how do i route my PCV valve. Im pretty sure i have it run worng right now, and it is causing alot of problems--whistling noise, and surging idle.
RE: how to route PCV?
The pcv sits directly in the lower intake.
The outlet hose from the pcv should run directly to the upper manifold.
Also, make sure the TB/VC hose is still in place.
Some aftermarket TB can cause whistling, especially at idle.
Then again so can a vac leak.
I guess a better description of the problem would help.
jason
jason
jwog666
12-27-2021 08:09 PM
