MM Panhard Bar
Old 09-21-2006, 03:58 PM
  #31
ruger311
Default RE: MM Panhard Bar
done have it in there, you guys were just talking about offers for parts so figured id stick this one in there,,,, when you gonna get all those pieces put on your ride? i had the same thing going on for about 3 mths i had all these parts laying around i finally took a week vacation and dedicated it only to my car, needless to say didnt get it all installed,
ruger311 is offline
Old 09-21-2006, 04:01 PM
  #32
88BlueGT
Damn that sucks. I just want to do lots of things at the same time to avoid tearing my car apart every week. I rather just dedicate a weekend every few months or something than every weekend ya know. When I get my a arms, coil over and struts I will do that long with the K member. Trans with the stall. And manifold, etc. with TB, MAF, EGR, Blower, PP, Crank Pulley, Injectors, FP and AFPR <--- That might take more than a weekend though
88BlueGT is offline
Old 09-21-2006, 04:06 PM
  #33
94RoadRacerGT
That is dirt cheap! Has it been installed? Make sure the bar or mounts have not been bent if it is used. I have seen what they can look like when dunces put a jack under them.
94RoadRacerGT is offline
Old 09-21-2006, 04:08 PM
  #34
88BlueGT
No the subframes were never even opened and taken out of the box until I asked the guy if they were coated or not lol And the panhard bar is also brand new and never installed. I am meeting up with the guy this Sunday to pick them up.
88BlueGT is offline
Old 09-21-2006, 04:09 PM
  #35
ruger311
yeah id say you are lookin at more than a weekend for sure, took me about a month of evenings including that week to get it all put together, and im still playing with little things, good luck with the install
ruger311 is offline
Old 09-21-2006, 04:12 PM
  #36
88BlueGT
I think I should be able to do everything in about 3-4 days at max. The thing is... when I work on cars. I WORK. I dont sit around take a break every 10 mintues, etc lol If I do it they will be 14-15 hour days!
88BlueGT is offline
Old 09-21-2006, 04:14 PM
  #37
94RoadRacerGT
I screw with it for about a week and then said to he77 with it and took it to a pro to get it done.
Old 09-21-2006, 04:18 PM
  #38
ruger311
usually pull the all nighters also, i completely stripped this car, repainted everything except the exterior, usually get home round 6 work on car till midnight or 1 then go to work at 7 am do it all over again 4 nights/week, weekends are reserved for the better half, its been a long time in the works, pretty fun to drive though, not sure if i want to take it to the next level with that HP turbo or not though, thinking paxton and 8" crank pulley 10-12lbs, or 125-150 shot, be all i need with this stock block,,,, dont really want to shell the cash out for a new dart, machining, turbo, and fuel system though,,,,
ruger311 is offline
Old 09-21-2006, 04:29 PM
  #39
vristang
ORIGINAL: Twister
It consists of a beam that bolts to the differential/rear axle, runs parallel to the driveshaft, and pivots at a point near the transmission output shaft. It prevents pinion angle changes (axle wide-up). When you install a torque arm in combination with a panhard bar or a watts link, they take over both functions of the Mustang's upper control arms (side-to-side axle location and prevention of pinion angle changes). Both of the stock upper control arms can be removed and discarded. Doing that gives you a 3-link rear. It exhibits almost no bind and performs much better than the stock system during extreme cornering, acceleration, and braking.
What your describing sounds more like what I have seen on the Chevy Rears, not how the MM PH Rod interfaces witht the Ford 5.0 Mustang.
Maybe I misunderstood.
I installed my MM panhard rod just aft of the dif.
Nothing runs up the length of the driveshaft.
Just curious if were talking about 2 different things.
jason
vristang is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
Want To Buy Ads
10-01-2015 10:52 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: MM Panhard Bar
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
