underdrive power pulleys 94/95 gt
#21
RE: underdrive power pulleys 94/95 gt
ORIGINAL: ikeybmg
i have 200 amp alt and with u/d on it it still would barely charge it idle. It drops to around 5volts every time the bass hits. Only drawing 375w max.
#22
ORIGINAL: AdderMk2
not true at all. My car does not charge at idle.
ORIGINAL: PX429
94/95 mustangs will not be affected in anyway with them.
neither does mine, but your alt isn't supposed to charge your battery. it is supposed to hold a charge.
#23
Yea, i really do need to get a capacitor. It draws my alt bad, it's just a punch 500 and 2 Power Hx2 12's. I wish I had a punch 800.
ORIGINAL: samseed101
If your bass hits that hard, then you should probably get a capacitor... or do you already have one? My Sub (when it's in) pushes 600 watts, and thats RMS not peak watts. I had to get 2 farad capacitor just to make sure it wasn't going to dim my lights or anything.
ORIGINAL: ikeybmg
#24
ORIGINAL: PX429
ORIGINAL: AdderMk2
ORIGINAL: PX429
#25
So,What i have is a 95 gt it has the stock radio still in thats it.Only other thing I have in it is a shift light.I had these pulleys for awhile sitting around there the ford motorsport svo.I having them put on tomorrow, and my car runs so good I just don't want these to affect anything I already new put not charging all that great but that it would still work.I just wanted to make sure by people that already have them on there 94/95 mustangs that they were happy with the outcome........thanks again
#27
ORIGINAL: PX429
What restores the battery power used to start the car if not the alternator?
The alternator runs the car once it is started, but it also recharges the battery as needed.
#29
ORIGINAL: Erich in Az
Ummmm....... What?
ORIGINAL: PX429
So when your battery is completly drained, you just jump and and let your alt. charge the battery? And people wonder why their alternators go out.
#30
you altenator will burn out from exesive use like from sound systems and crap and yea it would burn out from recharging the battery all the way like that, but a batter holds a charge if it didnt then you wouldnt be able to start your car, b/c the battery would be dead, a batter wont hold a charge tho after you drain it completely. you altenator is bassically a little power generator, it take mechanical energy convert its to electrical energy wich is then used to power your car and to restore the power taken from your batter to start the car
