suspension... im lost
RE: suspension... im lost
ORIGINAL: 86/02stang
Sorry about hijacking your thread but I have a question for 4fit? Where is graham NC. I go to school in Danville, Va and was wondering if you knew some people in the area. I see a fox body every now and then but don't see any congregate.
By the way, If you want drag and twisties, your going to need adjustables. Those are two different suspension setting. Not supposed to make a hard left while drag racing ya know. Personally, I'm looking at D&D's coilover set up. Give them a look. They have decent prices and alot of people stand by them on here. But like was said before, you need to get some subframe connectors. You don't want to ride on three wheels after a while. It will keep everything straight too. Apparantly torque boxes are a problem area but somebody else could help you with that. I don't even know what they are.
86/02 stang, the torque boxes are located where the upper and lower control arms attach to the chassis. It is very weak and thin metal. The reinforcements redistribute some of the initial shock of hard launches over a much broader area instead of just on the thin metal.
ok. So cut to fit plate metal would be fine to reinforce them, since all they really need is thicker metal to transfer the torque through
where can I get directions. I need to make it to a drag strip. I havn't smelled burnt rubber in a while. How far is it from Greensboro.
Also, check out www.PiedmontDragway.com
About 1 hour from Danville. Click here for directions
I would also recommend D&D for being on a budget. I am also looking for a suspension that will perform all around (twisties, street and strip). I already have my D&D K member, picking up MM Subframes and MM Panhard Bar on Sunday, and than Im going with D&D A Arms, D&D Front Coil Over, MM Control Arms, and not sure what stuts/shocks yet. Pretty sure Im going Koni's all the way around.
Sounds like a plan. My fiance doesn't get off work till 4:30 so it will be around 6:00 getting down there. Will the action going good by then?
ORIGINAL: 88BlueGT
