How big of a fuel pump to go? - Page 3 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 09-21-2006, 05:05 PM
  #21
grumpyphillips
Default RE: How big of a fuel pump to go?
Sorry guys. Typo. They are 19 lb injectors and the MAF was calibrated for them. Sorry for the typo.
grumpyphillips is offline
Old 09-21-2006, 05:06 PM
  #22
88BlueGT
Ok because that could be a problem with your idling, etc. if you had 19lb injectors and a MAF that was calibrated for 24's.
I would still toss that MAF and go with something smaller.
88BlueGT is offline
Old 09-21-2006, 05:11 PM
  #23
grumpyphillips
So, should I change the fuel filter and fuel reply before I change the fuel pump?
Old 09-21-2006, 05:13 PM
  #24
PX429
ORIGINAL: grumpyphillips
No, you just changed it a few months ago. that's not your problem.
Make sure it's your fuel pump before you change it. Run a pressure chck on it
PX429 is offline
Old 09-21-2006, 05:16 PM
  #25
7upedition
stock fuel pump flows 90 lph, and if your MAF isn't cal'd to the stock 19lb injectors then the motor will choke on the extra fuel and run very rich. i agree on the suggestions above, go 155prm intank fuel pump with external inline regulator and cal'd 73 mm maf. If your MAF is way bigger than your intake inlet port theres no point to it, you want to TB to match the intake inlet and the MAF to be a few mm bigger .... good luck, and clean the injectors that may help!
7upedition is offline
Old 09-21-2006, 05:21 PM
  #26
grumpyphillips
My injectors are brand new 19lb Ford Racing ones that were installed only 3 months ago.
Old 09-21-2006, 05:27 PM
  #27
7upedition
okay, thats great! is the MAF calibrated for 19Lb injectors?
Old 09-21-2006, 05:30 PM
  #28
grumpyphillips
Yes, the MAF is calibrated for the 19lb injectors.
10-26-2015 06:01 PM
LiquidDrink
09-29-2015 11:06 AM
schecterplayer
09-23-2015 09:38 AM
pimp2303
09-17-2015 09:45 PM
SteelerNation82
09-16-2015 08:11 AM
Quick Reply: How big of a fuel pump to go?
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
