carb pcv !!!!!
carb pcv !!!!!
when i got my car the guy had hooked the pcv hose to the vac tree and im scared that the oil will get in to my brake boosters and its not venting well, how do u hook the pcv system up on a carb car??
RE: carb pcv !!!!!
Normally the pcv vac nipple would be separate from the nipple for the vac tree. These need to be in 2 different places.
If you only have 1 vac nipple on the carb you can drill and tap another nipple on the carb, or convert to breathers.
Maybe someone else can make another suggestion,
but that is all I can think of.
jason
jason
RE: carb pcv !!!!!
i have a fitting coming off of the back of my carb and the pvc is hooked to it but it also branches off to the vach tree , should i just un hok the hose going to the vach tree and leave the pcv hooked to the back of the carb??? what all do i have to do to use breathers on my car?? here is a pice of what im talking about. click
Plz help , this thing is driving me CRAZY!!!
Thx
Justin
Thx
Justin
RE: carb pcv !!!!!
To run breathers...
Find a way to cap off the pcv hole in the intake, or stick a breather in the pcv hole. I would also add a second breather on one of the valve covers, possible one on each valve cover. The more breathers the better.
That is all you need to do.
If you only have one vac nipple on the intake manifold, then the breather option seems like the best option.
jason
RE: carb pcv !!!!!
For the kit to work you need a hole on each valve cover... if not, you could cut a hole in the second valve cover, but you wouldnt have a plate (baffle?) below the hole and i think you would suck oil then... at least in my case i know i would...
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
