BRONCO MISSES BAD WHEN FLOORING IT
09-24-2006, 09:46 PM
RE: BRONCO MISSES BAD WHEN FLOORING IT
Here you go....enjoy...check the "enrichment valve" under the main body...
09-24-2006, 10:38 PM
The Rogue Mod
Quote:
ORIGINAL: grabbem88
it's stock...probably is motorcraft...so there is a powervalve then...wasn't to sure on a two barrel..
the rebuild kits are like 20 bucks anyways.
thanks bernie.....i was thinking about the timing issue,and this truck fires up to easy for that...bump it and it starts..
Not saying that's the problem, but I had an 82 Capri 5.0 w/ a 2 barrel carb and that thing used to go thru them like no other. Good luck man.
Joel, nice diagram. Where are you getting this stuff from?
09-24-2006, 11:38 PM
joel you are the man...so the enrichment valve is more or less the "powervalve"?
09-24-2006, 11:39 PM
well i'd rather spend the 20 bucks rebuild it than mess with the timing chain right now...
09-24-2006, 11:46 PM
have you checked fuel pressure? I had the same problem and it ended up being a bad fpr.
09-24-2006, 11:49 PM
this is a big ol 400 carbed boat anchor...it has yet happened to me but the ol'lady said it came up the carb before..
09-24-2006, 11:56 PM
one more thing to add..i floored it one time and it about put me in the windsheild from the jerk it did to me.
09-25-2006, 01:09 AM
right click on the pci and selecy properties, this is where its from
autozone.com/images
09-25-2006, 02:14 AM
don't work
09-25-2006, 01:55 PM
well i thought i'd add this also...last night and this morning...while the motor was cold i went through the gears to 100 and it didn't do it at all,but as soon as it got to temp it was there..
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ThatJuanStang
09-25-2015 08:01 AM
