Fuel Pressure
Fuel Pressure
From what I have read in the past, fuel pressure should be set around 38psi. Arent you suposed to pull the vaccume line to the regulator off to check it? With the line on its 37, and with it off its 44. I just wanted to make sure before I buy an adjustable FPR
RE: Fuel Pressure
From the other thread you should have read
bottom of the page
bottom of the page
ORIGINAL: nitrous_bob
should be about 34 at idle w/ vac on
as soon as you give gas, it will start to rise to about 38-40 and wot or the vac line off it will go to 42 psi
mrappe
09-26-2015 10:16 AM
