Car is too low need help
My car is way too low and the exhaust always scrapes the ground over small bumps in the road and i can hardly go over speed bumps. When i have passangers cornering even slow makes it scrape. I think it has the eibach sportline springs on it so its something like a 2" drop. i'm putting new exhaust on the car and don't know what to do because it will still scrape, currently has side exhaust.....NEED HELP
RE: Car is too low need help
I have Eibach Sportline too and had that problem. I took my car a few weeks ago to get my axhaust system pick up higher. Got shorter hangers for it. It's way better. Thoght that might help you with the scraping problem.
Changing the springs would be the best option for a daily driver. Too many bumps and crap around to drop it that much. You can also try putting some poly spring isloators in the front and rear....I've been told they can raise the ride height up to .5".
i must be the only person who doesnt have problems with the sportlines.... i never scrape unless i go over a crazy speed bump.... im runnin 245's all the way around and the tires dont rub at all even when i turn the wheel all the way
i think also because i have side exhaust the pipes are much lower and scrape like crazy. I was thinking about having the exhaust go out the back and the entire system would be higher but i don't know if i will run into other problems. Another thing is it currently doesn't have mufflers, going to be purchasing some magnaflows soon but they are large and will scrape even more probably. Ah i don't know what to do
I think its a 94, i have my stock springs for the back from my 95, PM me if you want em. I might be able to get the fronts too. Lemme know
ORIGINAL: kevinas1214
What year is your car? If it is my year I have the factory springs and am willing to get rid of them!!
Yeah I have my stock springs from my 1994 if you want em let me know. I do want $20 plus shipping though
[IMG]local://upfiles/32281/2BAC7CD970754E6F92C08AD61760B00C.jpg[/IMG]
[IMG]local://upfiles/32281/3769411932674C4CA158DDC05709BDB3.jpg[/IMG]
[IMG]local://upfiles/32281/9075A87CC5FF46F4988C1039905D4EBB.jpg[/IMG]
