sn95 rotors on 87-93
i have a 88 mustang gt. do i need to grab the spindles rotors and calipars or can you just swap the rotors on it? also i have a 89 lincoln lsc but the rotors are shot are the the same spindles as the mustang? what is the best choice to convert to five lug i and taking the rear axle out and swaping that. but ill have to convert the front
thanks in advance
jonathan
thanks in advance
jonathan
RE: sn95 rotors on 87-93
ok, the MkVII rotors will bolt up to the 87-93 V8 spindle, grab the BIGGER calipers, direct bolt on, cheap way to get a 5 lug system. The SN95 system is best with the 99+ PBR calipers and 94-95 spindles on a FOX
ORIGINAL: Twister
If I was you I would just upgrade your rear diff to 30 spline and get 5 lug axles with it...i wish i would have
09-16-2015 07:53 PM
