Whats up with this engine?
So i'm looking at the car for sale and the guy put in a new 347 and only has 5500 miles on the engine but his listing says this " Sporadically blows out white smoke and the car seems to be running rich. I have had this checked out by Excessive motorsport and they couldn't find any problem or that there is a problem."
Does anyone know what this could be? Should i take a chance or is it not worth it?
RE: Whats up with this engine?
^^man is right about that. Trust your gut instinct. Don't go in blinded because it looks like the car your going to fall in love with. Test drive it and nit pick every little thing. Those little things are what become the big things. Just my 2 bits.
i have a 92 5.0 for sale its only got 24000 miles fully rebuilt motor 302 bored 30 over...eagle billit crank..eagle rods...forged pistons...trickflow heads ported and polished ford upper and lower pleneum...70mm throttle body...pro-m mass air meter....36lb injectors....SQ-trim votrech supercharger v-2....southside lower control arms.... welded torque box..... ford motorsport control arms...air ride in rear.....4pt roll bar...saleen interior(seats)....3:73 richmond gears...eighbach springs....brand new t-5 tremec tranny capable of holding 1000hp and a new ram clucth capable of holding 750.....the only things that would have to b done to the car is new rear hatchand alil cosmetic paint job to front bumper and alil on driver door...chipping... and after driving the car and the temp is at 190-200 the car for sum reason wont turn over unless cooler then 170 but other then that the car is great pushing 535 to the wheels... so if ur interested let me know and ill send pics via email
Running rich could just be an adjustment made somewhere.
As far as the white smoke I am assuming this is coming from the tail pipe. This is common with 347 kits that are a little on the cheap side or the company you bought the kit from has not perfected their kit.
What happens is because a 347 has a longer stroke which is induced by a crank that has larger push/pull aspects then when the crank turns and gets the 3oclock or 9 oclock positions (this is if you are thinking the bore hole lines up with 12 oclock) then the actual piston heads tilts just enough to let some oil through. Which then burns on that or the next cycle and there comes your white smoke.
This is a common problem among 347s....but again only if the kit that was bought was not from a company that has perfected that problem...
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
