Fuel pressure gauge
Any certain brands and such i should lean towards ? Its gonna be installed under the hood not in cab. I need that steel braided line, right ?
Its goin on a BBK adj. fuel pressure reg. if that matters |
RE: Fuel pressure gauge
Sounds easy enough. Thanks
I went with an Autometer and i mounted it on top of the cowl panel in a gauge pod. Simple as that.
Mine is mounted on the fuel rail off of the schrader valve.
I'll figure out a good ol spot to mount it
ORIGINAL: 92hatchLX Mine is mounted on the fuel rail off of the schrader valve. |
