how bad could beat my friend?
1989 Mustang Anniversary Model LX Hatchback
Engine
Customer computer chip by hypertech
Edelbrock Stage 3 aluminum heads
Manley Race Flow stainless valves
Heads have been fully ported and polished
24 lb injectors on a billet fule rail (fully calibrated)
SVO 1.6 rollers E303 motorsport camshaft
Fel-Pro gaskets and ARP bolts
Ported GT40 lower intake
Ported Corba upper intake
Uderdrive pulleys
75mm pro M Mass air meter/70mm throttle body
K&N airfilter & Moroso cold air power pipe
Jacobs electronics
130 AMP alternator by PA performance
MAC headers new H pipe & CATS
Suspension & Drive Train
Hurst short throw shifter
SVO aluminum drive shaft
Motorsport 3:73 Ring & Pinion
Maier upper strut brace
Aluminum rack bushings
Maximum Motorsport subframe connectors
Maximum Motorsport panhard bar
Maximum Motorsport lower K brace
Suspension Technique sway bars front & rear
Koni shocks
Motorsport rear disc brakes
Baer front 13 inch track disc brakes
Cobra 'R' Chrome 17 inch wheels w/ B.F Goodrich tires
Center force clutch & pressure plate
Aluminum clutch quadrant
Eibach springs
Maximum Motorsport adjustable rear control arms upper & lower
My friend has a 2000 Firebird Formula with jus flowmasters on it.. could i beat him?
anybody have an aproximate horsepower rating for both cars?
Engine
Uderdrive pulleys
Jacobs electronics
Koni shocks
Eibach springs
RE: how bad could beat my friend?
i think my friends car has about 270hp.. the reason im asking this is because i am looking at buying this mustang.. and my friend and i have been discussing about who will win..
Your budy has an LS1 powered Firebird, they made about 350hp or 270-290rwhp.
it will be a good race but you should be able to take him with that set-up
that should be making right at 300rwhp+
he'll be a little faster on the top end, but you should take him off the line pretty good.
ORIGINAL: nseoi
sidenote, isnt the anniversary edition 1990?
just verified from themustangsource.com
"Mustang celebrated its 25th Anniversary with a limited edition of 2,000 special edition cars. Although the anniversary year was technically 1989 1/2, the limited edition was a 1990 model. They all came in Emerald Green, and were called 7-Up cars because Ford made a green and white convertible for a 7-Up ad, but the contract fell through"
