Next Mod Poll
OK I'm getting my new exhaust installed on Friday and my Spec Clutch installed tomorrow and I'll get the tuner in sometime between them so now what do you think should be my next mod? If other then please specify. Here is a copy of my current mod list, both performance and visual.
Intake 1.) BBK Cold Air Intake (complete) 2.) Polished Trick Flow Street Heat Intake Manifold 3.) Polished Trick Flow Elbow Adaptor 4.) Polished 75mm Throttle Body 5.) 90mm High flow Mass Air Meter Tuning 1.) Tweecer RT Real Time Tuner (complete) Engine 1) BBK Aluminum Under Drive Pulleys (complete) 1) GT-40 Heads 2) Mild Tune Cam 3) 24lb Ford Racing Fuel Injectors 4) BBK High Flow Fuel Rails 5) BBK High Flow Fuel Regulator 6) High Flow Fuel Pump 7) Forged Pistons 8) Forged H Piston Rods 9) Forged Piston Rings 10) Forged Crankshaft Ignition 1.) Blue Ford Racing 9mm Spark Plug Wires (complete) 2.) MSD Distributor Forced Induction 1.) Tunable 75-200 Wet Shot Zex Nitrous Kit 2.) 9psi Vortech Supercharger 3.) Vortech Intercooler Exhaust 1.) BBK Ceramic Coated Shortie Headers (complete) 2.) Bassini Off Road X Pipe (complete) 3.) Magnaflow Dual Cat backs (complete) Transmission/Driveline 1.) Steeda Tri Ax Short Shifter (complete) 2.) Spec Stage 1 Clutch (complete) 3.) 3.55 Ford Racing Gears (complete) 4.) Detroit True Lock Differential (complete) 5.) G-Force T-5 Transmission Upgrade Kit Suspension 1.) Eibach Pro Shocks for 1.5” - 2” Height Drop (complete) 2.) Eibach Shocks (complete) 3.) Adjustable Caster Cambers (complete) 4.) Ford Racing Front Sway Bar (complete) 5.) Ford Racing Rear Sway Bar (complete) Body 1.) 14” Shortie Antenna (complete) 2.) 17” Aluminum Cobra R Rims (complete) 3.) Clear Tinted Cobra Headlights (complete) 4.) 96-98 OEM Black Taillights (complete) 5.) 302 Badges (complete) 6.) 25% Window Tint 7.) Urethane Saleen Body Kit 8.) Urethane Saleen S-281 Wing (semi complete) 9.) Yellow Paint With Saleen Paint Scheme Interior 1.) Ford Racing Steering Wheel Cover (complete) 2.) Ford Racing Billet Shifter Knob (complete) 3.) Satin Door Sill Inserts (complete) 4.) Billet Pedals (complete) 5.) Running Pony Floor Mats (complete) 6.) Steeda Aluminum Door Handles 7.) Corbeau Racing Seats (Black, Yellow) Audio 1.) Sony X Plod 250W Stereo (complete) 2.) 4 5” X 7” Eclipse Speakers (complete) 3.) 2 Boston Tweeters (complete) 4.) 2 10” JL Audio Subs (complete) 5.) Sealed Dual Sub Box (complete) 6.) 1200W Sony Professional Series Amp (complete) 7.) 4 Gauge Amp Power Cable (complete) Engine Bay Dress Up 1.) Chrome Gas Hood Shocks (complete) 2.) Blue Hose Covers (complete) 3.) Blue Good Year Radiator Hoses (complete) 4.) Paint All Pulleys Billet Aluminum 5.) Ford Racing Chrome Dip Stick 6.) Steeda Chrome Oil Cap 7.) Steeda Chrome Fuse Box Cover 8.) K&N Valve Breather Filter 9.) Ford Racing Valve Covers |
