Need help with compression test
I was told I should do a compression test on my motor before I pull it so I will know if I need to rebuild it.
Can anyone tell me what I should have for compression for my 85 GT?
Also, I don't have the capability of checking it here. Should this be done at the dealer? If I do it myself, what do I need?
Thanks
[IMG]local://upfiles/48432/8E2ED5C7394D4AE3889EDB7F509DE46C.jpg[/IMG]
Thanks
RE: Need help with compression test
I am pulling the motor because the car is getting repainted. The engine has it's typical small leaks here and there so I planned on replacing as many seals/gaskets as I could while the motor was out. I guess if the compression was low, would I have less power? I don't have anything to compare it to. If it is lower than it is supposed to be, I would like to do what I have to to bring it back to spec (stock).
The engine compartment is covered with rust proofing and I need to remove the motor to clean up the rust proofing before painting.
[IMG]local://upfiles/48432/E3F5A394E4F04E41AFD99AD871AC01C3.jpg[/IMG]
Sorry... The motor seems to run good. No smoking and seems like plenty of power. It does run a little hot but I just got a new fan clutch to see if that will fix that problem.
The car 72,000 miles on it.
Here is a link on how to do a comression test... Oh, and i argee... bold is annoying...
http://www.motorage.com/motorage/art...l.jsp?id=16170
