/24lbs injectors???
/24lbs injectors???
hi i just put a h/c/i setup from trick flow on my 1989 mustang 5.0 and i was wandering what do i need now??
Are my 19lbs injectors just fine?? or do i need 24lbs ones
Do i need to change the fuel pressure?? and fuel pump???
RE: /24lbs injectors???
You should be fine with 19#ers for now, and your stock fuel pump should put out enough. I dont think you really need bigger injectors unless your SC, turbo, or have nitrous. I think 19#ers are good for up to around 300-320 HP.
