Max lift before piston/valve issues ?
RE: Max lift before piston/valve issues ?
Total valve lift is not directly related to PtV issues....when the valves are at total lift, the piston is way down in the cylinder....it's the overlap period (exh/intake valves are slightly opened at the same time when the piston is reaching exhaust TDC) that is required to be checked.....
Suggest to check http://www.fordmuscle.com/fundamentals/pistontovalve/
with stock 1.6 roller rockers and valves no larger than 1.94 intake, 1.6 exhaust your good up to .550 lift, .224 -.230 duration, after those number CHECK.
Machinist/Race Car Builder gave me this info
1.7's add .027 lift to any cam , in fact the cobra has 1.7 roller lifters
ORIGINAL: aode06
You really should check with all cam installations, but I'd definately be worried about anything OTS that is more than .540 @ 224*. I think you'll have problems with more duration than that on most OTS cams.
