What to do with the money
RE: What to do with the money
Get the gears... but that will take atleast half of your money. Gears + Installation Kit (100 Bucks) + Gear Oil + Speedo Gear + Installation = About $550.
Than take what you have left and try to do your exhaust with it.
ORIGINAL: 86/02stang
Gears, exhaust, nitrous and intake. Like was said above, you should bump your timing. If you have any left, get yourself some sticky tires.
If you only have $1000 bucks to blow then I would suggest you go with gears and exhaust. I would love to find somewhere you could get gears installed for $350. I would be guessing something like $500 for an install. The other half of your money would be best spent on exhaust. if you use an o/r pipe, you might be able to get some headers. Hope this helps a little.
